C-clip eliminator installation - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2007, 12:43 PM
Hello!
I'm doing c-clip eliminator(Strange) installation and I got some questions. Do I still have to install axles with those c-clips or can I throw them away? Does c-clip eliminator replace c-clips and hold axles on place or are they just safety equipment in case c-clips fail? It's a GM 8,5" 10 bolt with Powertrax lock.
Thank you!
Camaro80
Old 02-18-2007, 01:42 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
I'am sure your c-clips are the same as my 12 bolt. You no longer use the c-clips. The eliminators are pressed onto the axles and bolt up to the brake backing plates holding the Axel in place. A lot like the 9" ford setup.
Old 02-19-2007, 12:29 AM
Tribal's Avatar
THUG LIFE
You also will have to cut the axle housing ends off at the outside of the brake flange to bolt up the c-clip eliminators.
mustang front clip Stangman196700 Body - Exterior 2 09-24-2004 08:43 PM
nova front clip beetle9 Suspension - Brakes - Steering 5 09-20-2004 02:08 AM
mustang front clip swap 2wld4u Body - Exterior 5 11-02-2003 10:07 PM
Hotrodders Knowledge Cluster: Front Clip Installs/Subframes/Frame Swaps Jon Suspension - Brakes - Steering 0 10-12-2003 04:56 PM
front clip retrofit beetle9 Suspension - Brakes - Steering 1 01-09-2002 03:24 PM
