a/c compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2013, 08:39 PM
a/c compressor
Can Anyone answer a/c questions ?
Old 07-07-2013, 08:53 PM
LATECH's Avatar
Absolutely.
Fact is stranger than Fiction
techinspector1's Avatar
Wiki Edits: 326
Yes, anyone at all.
Old 07-07-2013, 08:57 PM
LATECH's Avatar
Originally Posted by techinspector1 View Post
Yes, anyone at all.
Correctly or otherwise.... LOL
Old 07-07-2013, 09:07 PM
I have a a/c compressor from around a (78-80) camaro my nephew gave me for my 76 f/bird . They look very similar in all gen areas. The 76 has an elec. con. just below the mounting of the hoses at the rear of the comp. It's a pointed prong like a pen and the plug is a small wire that leads to the 3 prong fuse /relay that disable the a/c comp. when it blows . The newer comp. does'nt have this conn. and the mounting bracket bolts are also metric and the old one is standard thread. That I thought would just need m bolts. Can this swap be done ? Thanks
Old 07-07-2013, 10:27 PM
Wiki Edits: 326
Can this swap be done?
Yes, of course. Like I always say, with a 220 amp MIG, an acetylene cutting torch, a Sawzall and a good 4" hand grinder, you can swap anything into anything.
Old 07-08-2013, 07:05 AM
Where do you start with that amount of tools out on the bench I'm not sure which end to start on ????
Old 07-08-2013, 07:37 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That sounds like the superheat switch terminal. If that's the case the compressor will function normally w/o it being connected, although it's there to sense a problem w/the system so that function will be lost.
Old 07-08-2013, 11:06 AM
75gmck25's Avatar
The only two GM compressors I've seen from that time period are the older A6 (about 12 inches long, iron, very heavy) and the R4 (about 6 inches long, bigger in diameter, much lighter). They were used on hundreds of thousands of GM cars over the years. Using all the AC components from one year on a different year car is usually easy, but mixing and matching components between years means you need to understand both systems.
The minimum you really need is the compressor, condenser and evaporator, hoses, an orifice tube and orifice (I think they had switched to that setup by '76), a low pressure switch, a temp probe and low temp switch, and the power connections to the compressor to turn it on. There will also usually be an A/C high speed blower relay, and of course you need an operating fan.
- You switch the A/C on and the current runs from the dash through the A/C relay and low pressure cutoff switch (is the system charged?) and then through the low temp switch (is it so cold that the compressor should not run?), and then over to the A/C compressor.
- If the system has the right charge of R134, there are no leaking hoses, and the compressor is working, it will now cool.
- With R134 its usually best to switch the orifice from a GM white to a Ford blue orifice. You usually charge the amount of R134 at about 75% of the charge of original R12 Freon. You will need hoses with R134 fittings, or you will need to screw on adapters. Its also recommended to add a high pressure switch cutoff also, since R134 pressures can go higher and burst a hose.
- You also need good air flow through the condenser with R134, so use a good OEM fan with a HD fan clutch. A new parallel flow condenser would also improve performance, but you would have to customize a generic parallel condenser installation to make it fit.
Bruce
Old 07-08-2013, 11:49 AM
Side by side they look alike and are r12 freon . The main diff is the elect. con. and the diff of standard /metric threads on comp . itself. That's a big yes about heavy ! The newer one has a little larger diameter in size also but the V seems to be the same size !
Old 07-08-2013, 04:45 PM
LATECH's Avatar
The switch is the low pressure cycle switch.
Remove the circlip, pull out the switch and put it in the 80 camaro compressor.
Not too likely that youll find the answer over at PSP.
Old 07-08-2013, 05:01 PM
There's no place to put it on the newer one or atleast not anywhere near the same location . ?
Old 07-08-2013, 05:06 PM
LATECH's Avatar
Then run the low pressure switch that screws on the drier instead.
You may be right , but look the compressor over well.
There may be a plug in the hole that needs removed for the switch to go in.
Old 07-08-2013, 05:46 PM
I'll see if I've overlooked it and see if I can find one on the drier , Thanks
Old 07-08-2013, 06:12 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A6 compressor w/super heat switch:
A6 SH switch only (there are a couple different looking types of SH switches:
Most high/low pressure cutout switches resemble this IIRC:
Eaton Compressor threatens to sue me over "Made in China" compressor post Jon Hotrodders' Lounge 190 03-06-2015 06:11 AM
Anybody own or have info for a 5hp 18.5 80gallon blue Excel Compressor air compressor snapped finger Garage - Tools 0 03-24-2013 11:33 PM
Old Compressor Mac88 Garage - Tools 7 02-01-2013 06:16 PM
compressor alf1096 Engine 1 07-29-2005 08:33 PM
The right compressor for me? daveh Body - Exterior 3 11-05-2004 03:57 PM
