A/C Compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2004, 07:10 AM
New Member
A/C Compressor
my a/c compressor isn't getting power, ground should be good, what switch might have gone bad?
76 Silverado
Old 05-07-2004, 10:37 AM
willys36@aol.com's Avatar
Wiki Edits: 21
I assume you mean the clutch on the drive pulley. Very easy to check - turn on the AC and check for voltage @ the clutch. Zero voltage means switch/wire/fuse problem. Track it down using wiring diagram and circuit tester. If there is ~12V there, you have a bad clutch (they do burn out occasionally) and will need ot replace it.
Old 05-07-2004, 11:20 AM
BstMech's Avatar
NYOFP4RJ3CHRIS
The low side switch could be open, because you are probably low on refrigerant.
Old 05-07-2004, 03:08 PM
New Member
Got out under the shade tree, the compressor, clutch and refrigerant are all new, replaced back at the end of last summer; everything was working...
So now, a hot wire goes into the thermostat-type swith (clutch engage--both terminals are hot when power is hooked up)--
power then goes to the prerssure-cut -out swith, power does NOT flow thru this switch....
So I bypassed the pressure cut out switch, hot power at the clutch, but it still didn't kick on.
Suggestions appreciated!....
CF
Old 05-07-2004, 03:56 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
You now have hot to the clutch, how's the ground?
