A/C Compressor Wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2010, 11:40 AM
tc33's Avatar
Stuck in the 30's
Last journal entry: Where it came from and how I got there - a short Summary
I'm finishing up wiring the controls for the Hot Rod Air System I'm installing.
I have an EZ Wiring harness and have two black wires;
One marked A/C Power (obvious on how and where to connect that one)
One marked A/C Compressor (not sure where to connect this one??)
Both are black
both are the same gauge
both terminate under the dash
There are no blank terminal lugs on the A/C switches. There is a sperate thermostat control. Would it be attached to the thermostat to kick in the compressor at a certain temp??
Any clues as to where and how it would connect???
Old 07-31-2010, 01:56 PM
65ELCMO's Avatar
there is one black wire comming out of the clutch on the compressor, It goes there
Old 08-01-2010, 07:57 AM
Compressor wire usually goes from the compressor, through the high and low pressure cutoff switches, then to the temp switch in the plenum, and then to the A/C controls.
Bruce
Old 08-02-2010, 05:42 PM
tc33's Avatar
Stuck in the 30's
A/C Wire
"Compressor wire usually goes from the compressor, through the high and low pressure cutoff switches, then to the temp switch in the plenum, and then to the A/C controls. "
Bruce,
I found the wire you referred to under the hood and all is connected under the hood as you stated. Still got the one wire under the dash. Where would I connect that one and to what A/C control. All three controls (Fan Speed switch, heat a/c, vent and defrost selector switch and the temp adjust switch) that came with the Hot Rod Air kit were pre-wired with only one blank plug which is marked do not use???? I believe that was on the fan speed switch.
To leave or keep A/C chevyguy General Rodding Tech 13 08-14-2010 04:06 PM
Underhood air compressor from A/C parts F&J Garage - Tools 4 07-25-2008 08:56 PM
A/C belt mitmaks Engine 2 08-02-2007 05:27 AM
Should I remove my A/c 1970Chevy General Rodding Tech 2 07-08-2007 10:22 AM
A/C question Paco Engine 1 06-03-2002 07:01 PM
