A/C Compressor Wiring
I'm finishing up wiring the controls for the Hot Rod Air System I'm installing.
I have an EZ Wiring harness and have two black wires; One marked A/C Power (obvious on how and where to connect that one) One marked A/C Compressor (not sure where to connect this one??) Both are black both are the same gauge both terminate under the dash There are no blank terminal lugs on the A/C switches. There is a sperate thermostat control. Would it be attached to the thermostat to kick in the compressor at a certain temp?? Any clues as to where and how it would connect??? |
I have an air compressor, when i bought it, it said it could be used with 110 or 220 current. I am wiring it with 110. where it hooks up there are 3 terminals. one has a red wire, 1 with a black wire, and 1 blue. i need to know which is positive, negative, and ground.
Last edited by T-bucket23; 08-04-2010 at 08:21 AM. Reason: Violation of guidelines. Please see: general board guidelines. |
I've got a HRA setup that I'm doing in an El Camino. You probably have the same controls that mine has and the wiring layout will be like this.
If you look at the thermostat switch there are 2 blue wires connected, one from the switch and the other long blue wire with a connector on the end. That long blue wire is what connects to the compressor and would be the one replaced by the compressor wire in your new harness. ![]() By the way on my El Camino I did away with the HRA controls and converted the original factory controls to operate the unit.
Double post ....sorry
| To leave or keep A/C | chevyguy | General Rodding Tech | 13 | 08-14-2010 04:06 PM |
| Underhood air compressor from A/C parts | F&J | Garage - Tools | 4 | 07-25-2008 08:56 PM |
| A/C belt | mitmaks | Engine | 2 | 08-02-2007 05:27 AM |
| Should I remove my A/c | 1970Chevy | General Rodding Tech | 2 | 07-08-2007 10:22 AM |
| A/C question | Paco | Engine | 1 | 06-03-2002 07:01 PM |
