a/c control panels - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2012, 08:49 PM
a/c control panels
Would like to add a/c in my car but I will be doing an engine swap and rewiring everything. None of the stock under dash wiring will exist. I will have a toggle switch panel and now Im looking for an a/c and heater control panel. Something that is as easy to wire as 1,2,3 for each knob. No factory plugs and groups of 10 wires per switch.
Anyone make something like this that I can retro-fit into my dash?
Old 03-13-2012, 07:37 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Moving this to General Rodding Tech.
Dan
Old 03-13-2012, 11:36 AM
327NUT's Avatar
look at www.vintageair.com
Old 03-13-2012, 03:38 PM
Are you keeping the factory heater and air components? I don't know what your working on but if its got those items and you still want to use them, stick with the original set up. It won't matter what engine or compressor you use the wiring will be the same. If you want blower speeds and be able to control your heat/ac temps you'll be basically duplicating the factory wiring. If you are running just a/c go find a old after market hang on unit and use the wiring from it. That's about as basic as you can get
control/ a arm todo66 Suspension - Brakes - Steering 1 11-04-2008 06:35 PM
How do you layer panels on door panels genr8rs Interior 6 04-05-2006 07:24 PM
4th Control ARm????????? Toni Pepperoni Suspension - Brakes - Steering 7 09-23-2005 08:49 PM
Panels boofis Body - Exterior 6 01-27-2005 01:31 AM
GTO panels Vaughn68 Body - Exterior 2 10-09-2002 12:59 PM
