a.c
Did you use GM [white]?Is it backward.Aside from tha,yur hi side is way low.Onr trick on changeover is to put a older ford cycle switch r-12 ,these are adjustable.Then you can adjst cycle time-cycle off say15 to 20 psi.One other thing my be junk you could not get out pluging orfice..Concerding your presure I would check orfice anyhow.
