Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - A/C cycles, 3lbs installed
Old 03-03-2007, 10:19 AM
grandpaws 57's Avatar
grandpaws 57 grandpaws 57 is offline
"Don't need no V/8"-grandpaw
blows cold
well at least its cold.Under lite heat load you can have a low high side .Mabey a diff. of 50lbs between low&high.Could you shocked comp with oil? Hope it helps
