C/H DP5810-Q Compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2010, 12:36 AM
Hi all. Fairly new here. I've been looking into maybe buying this compressor at Lowe's. It's A C/H. Specs are 5 horse, 208-230, 19-21 amp.(WEG) motor is made in Brazil. 14.2cfm @140 psi. 16 cfm@90. 140 psi max. 80 gal. The compressor on it is a single stage cast iron four cylinder. Price on it is 799. I can get 10% off on it right now. I'm hoping it will fill all my compressor needs.
I was wondering if anybody has one or can give me any feedback on this piece of equiptment. I haven't found any ratings on this compressor. Any information would be really appreciated. Thanks
Old 03-22-2010, 06:54 PM
rusty 87. You are a real CLOWN! You need to get the biggest tractor you can get to pull your head out of your anus. Go with a two stage I/R, Quincy or any of the better brands and you know which ones they are. With at least a 5 horse, 220 volt. 22 or higher amp rating and no less than a 60 gal. tank.
So cut loose those purse strings you tight wad scrouge and get what you really want. Don't be posting B/S stuff up here and wasting everyones time untill you have done a thorough SEARCH on what ever little thing your pea brain comes up with! Good Bye.
Eaton Compressor threatens to sue me over "Made in China" compressor post Jon Hotrodders' Lounge 190 03-06-2015 06:11 AM
will this air compressor plan work? snorulz Garage - Tools 16 05-07-2012 10:34 AM
Used compressor - rusty tank? Slipangle Garage - Tools 15 03-16-2012 08:51 AM
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
air lines CARGUY Garage - Tools 96 11-16-2006 04:11 PM
