A/C in the home garage - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2006, 10:55 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
What do you guy's think? I have been doing a house addition for the last year or so, and with that I upgraded to a larger central A/C system, my old one was only approx 10 years old and worked very well.
So I was thinking about installing it and the old furnace into my garage at home, I have all the parts I would just have to have it recharged after the install.
I live in Michigan so the heat is not all that bad, but most of my garage time is after 7:00 at night so I would be doing it more for bug control than heat control.
What do you guy's think, should I do it or not?
Steve
Old 06-29-2006, 11:08 AM
Last journal entry: Free tires
Attached or detached garage? What type heat?
I have heat and AC in my 1000 ft detached. Love it. Free is a great price as well. Help your resell value to.
Check here under heating and ac for more garage info.
http://www.garagejournal.com/forum/
Old 06-29-2006, 11:19 AM
1931 steve's Avatar
Wiki Edits: 4
Attached, forced air, with natural gas.
Steve
Old 06-29-2006, 12:32 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I would if I had that..install it in the garage..and if you place it so it blows in you can have filtered air when you need it..Place a filter bank on the on the intake side..and filter outlets on the other end of your shop..
Just use the thinking cap and it will all work out..
Sam
Old 06-29-2006, 03:29 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
I'd do it.
Old 06-29-2006, 03:44 PM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
i would so do it !
as a car guy, im sure you spend enough time in the garage to get good use out of it. and it will definantly help on those muggy days
set up a filter system like previously mentioned and it will keep the garage fre of fumes from welding, grinding, painting, doing fuel related tasks ect
Old 06-29-2006, 03:54 PM
Redman Racing
Check local codes. You may not be allowed to put duct work or any filtration in the garage.
Old 06-29-2006, 04:03 PM
Redman Racing
Sam
I don't exactly know what you mean but there should be no return air going back into the furnace from a garage or kitchen.
Old 06-29-2006, 04:14 PM
Wiki Edits: 3
One does not use return air ..one takes air from outside runs thru the air handler and then into the garage..totally different from a normal HVAC system..
Old 06-29-2006, 04:25 PM
Redman Racing
is this system just for the garage? or does it supply the rest of the house as well?
Old 06-29-2006, 04:49 PM
1931 steve's Avatar
Wiki Edits: 4
This will be just for the garage. I already have a forced air furnace in the garage now so I will replace it with my old house furnace and A/C unit. I just installed a new Train furnace and A/C unit for the house. I have made my house just over double its original size so I had to install a new setup. I will run a fresh air make up to the furnace, for the proper fresh air.
Old 06-29-2006, 04:57 PM
russlaferrera
Last wiki edit: Threading tips
Wiki Edits: 2
ac in the garage
I have a 1500 sq ft garage that is air conditioned with a large window unit at ceiling hight. . There are no ducts. No thermostat. Just a on/off switch.
A simple system and it works great.
As you know cold air drops so aim it toward the ceiling. With enough fan you will not need any duct work. You do not have to balance any rooms with air flow. you need a filter on the intake to keep the coil clean.
Just a suggestion.
Old 06-29-2006, 05:32 PM
Redman Racing
Since the garage is attached to home did you use 5/8 fire rock seal all opening into the home from garage with fire caulk and put in a steel fire door that you will be using to enter the living space. Codes hear are stricked.
Old 06-29-2006, 05:58 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
Just a suggestion.
Mine is 440 sq.ft. detached and I've thought about doing similiar. But I've had a couple of questions about doing it that way.
1. Are most of the same size rated (say 20,000 BTU i.e.) the same size or close to it for future replacement purposes?
2. Do I need to do anything to minimize the chance of wall damage (extra bracing under it or for fire protection)?
3. You kinda answered part of it in yours, but do you leave it installled 365 or take it out? Have you got a cover over the exterior parts, do you tarp it in the winter?
Thanks, Chet.
Old 06-29-2006, 07:19 PM
russlaferrera
Wiki Edits: 2
a/c
Chet, My ceiling hight is 16 feet, This means to me the following:
It stays in 365.
I found it hard to adjust the thermostat. So a switch on/off works for me.
I never cover it.
I acid clean the coil every 3-3 years
To answer your questions The hole for the a/c is about4 inches larger. The trim is used to allow me the flexibility to install a replacement unit. The unit is supported by 2 angle iron brackets on the exterior.
The system was used when I bought it and I have been using is for the past 14 years. It never has been recharged. (Now it will blow up )
Need help deciding on garage heater Xenocide Garage - Tools 20 01-05-2008 09:54 AM
100 AMP Service In Garage Help daveh Garage - Tools 9 02-27-2005 01:15 AM
cover it portable garage helrazr3 Garage - Tools 9 12-12-2004 12:50 PM
Refinance for my garage. HemmiGremmie Hotrodders' Lounge 5 10-31-2004 04:26 AM
"Smart" garage and a magazine? McDeuce Garage - Tools 4 01-08-2004 08:22 PM
