c.i.d. for a 383 bored .060 over??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2006, 09:02 PM
kuhn-77's Avatar
Build it right the first time
i just built a 383 stroker that i bored .060 over i was wondering what the ci. of this motor would truly be....?
Old 08-16-2006, 09:10 PM
I would say 388.
Old 08-16-2006, 09:33 PM
WDCreech's Avatar
Grumpy Old Goat Herder
Do it the old way....... 1/2 of total bore squared times pi (3.1415927), times stroke, times the number of cylinders.
Old 08-16-2006, 10:10 PM
camaroman7d's Avatar
Let's make sure we are on the same page. you had a 383 (4.030" bore X 3.75" stroke), you now have a 4.060" bore X 3.75" stroke, correct? If so then it is a 388. If you had a stock 4.00" bore and 3.75" stroke it would be a 377.
What you did is bore the 383 .030" over not .060" over.
Old 08-16-2006, 10:22 PM
327NUT's Avatar
Heres another formula to figure cubes, just found this one myself.
Bore x Bore x Stroke x 0.7854 x 8 ....or number of cyl. you have.
4.060 x 4.060 x 3.75 x 0.7854 x 8 = 388.38 CI
Old 08-17-2006, 01:02 AM
trucks_chevrolet's Avatar
A 350 block + 350 crank = 350
a 350 block + 400 crank = 377
a 350 block+.030 bore + 400 crank = 383
a 350 block + .060 bore + 400 crank = 388
hope that explains it simply
Old 10-21-2006, 08:20 PM
kringold's Avatar
ATA Welding Technology
Last wiki edit: How to rebuild an engine Last photo:
What's a 350 block + .060 bore + 350 crank = ?
and a 350 block + .040 bore + 350 crank = ?
Old 10-21-2006, 11:05 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
With a stock crank,
60-over is 360.4
40-over is 356.9
30-over is 355.1
Old 10-21-2006, 11:16 PM
If you plan on boring a 350 .060 over its a good idea to have the cylinders sonic tested for thickness as we find very few that would be safe or have real good real seal at .060
Ok, here's the debate of the century: 383 or 400 chevy!! Cast your vote and reason killerformula Engine 303 03-28-2013 08:08 PM
350 bored .060 over... XE268 cam, I didn't put a CAM BUTTON IN!!! Dizturbed One Engine 12 08-08-2010 08:50 AM
383 Stroker .060 over Questions kuhn-77 Engine 8 07-29-2006 07:29 PM
440 bored .060 over johnsoge Engine 2 05-14-2005 04:45 PM
.060 bored 350 its_all_good Engine 3 04-26-2002 06:51 AM
