c.i.d formula - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2007, 08:40 PM
c.i.d formula
hey every 1 i have a question ?
in the c.i.d. formula what does the 0.7854 stand for
thanks
Old 01-24-2007, 09:18 PM
ericnova72's Avatar
More for Less Racer
c.i.d. formula's
The number 0.7854 is 1/4 of 3.1416 (pi).
The formula I've found to be the simplest to use is: bore x bore x stroke x 6.2832 = cubic inches for a V8. Change 6.2832 to 3.1416 for a 4-banger or to 2.3562 for a 6-cylinder. See the connection? 2 pi ; 1 pi ; 1 and 1/2 pi.
Old 01-24-2007, 11:39 PM
FordMan1951's Avatar
Ford Man to the bone!!!
pi r squared = area of circle
or
3.1416 * Radius * Radius = area of circle
In math the times and division parts of a formula can be moved around without changing the results.
Because of this:
Move Pi to end and you get
Radius * Radius * pi
or
bore / 2 * bore / 2 * pi
rearange it again to be
bore * bore * pi / 2 / 2
or
bore * bore * pi / 4
or
bore * bore * 0.7854
Got it?
displacement formula minesblown Engine 13 01-25-2007 08:28 AM
Gear ratio formula? AC/DC General Rodding Tech 4 10-13-2006 06:40 AM
looking for a metalic red formula TheCiscoKid Body - Exterior 4 02-15-2006 10:00 AM
engine timing: formula onecoomofo Engine 1 04-01-2004 08:35 AM
Formula 500 steering box deltr0n Suspension - Brakes - Steering 2 10-04-2002 02:12 PM
