a/c improvement
I have a 73 drive train (Camaro 350) with a Vintage Air a/c system that was installed in 1990. Recently had a relay meltdown with shorting of the hot wire into the ignition. After getting all that straightened out, which included a new wiring harness from Vintage Air (with an inline circuit breaker fuse on the hot side), I noted that there is no binary switch in the system. It has a reconditioned Harrison type compressor, and all joints are barb and crimp. I have a drier that has a sight window.
Question:
1. Should I install a binary switch? My electric fan is hand operated from the dash, which I am used to, so I don't need the trinary type switch.
2. Assuming that I install the binary switch,(there is low residual of R12 that I will have to deal with) and I cut the line and install quickly, is there any need to pull a vacuum on the system before I charge back up with Freeze 12?
3. Where is the best place to place the switch?
rap
