First you have a leak. That is why it works a few days then quits.
Second the low pressure switch kicks off at 28 psi. you need more juice. |
Second this one. Leak and low freon causing the fast cycling |
That could be a third it, but, without knowing the high sides. you can't be sure. Many have a high side pressure safety also. But you guys probably have it correct.
Let's not forget to mention that most new vehicles do NOT have a receiver dryer nor an expansion valve, that is why they have a low pressure cycling switch on the low pressure/suction side of the system. I'm fairly sure this is an accumulator/orifice tube system.
Rethinking this: If the static pressure is 80 then there must be 134 in there. 80 might be fine depending on the ambient system temperature. What's the high side? Adding 134 to keep the low side above cut-off might make the high side extreme. 134 is very temperature sensitive. Consult a temp/pressure chart for 134 by google.com. http://dodgeram.org/tech/repair/HVAC/R134a.htm 80* ambient system temperature would mean 87* static pressure. You say yours is 45 psi static? Definitely low on gas. Remember, a hot engine compartment will make the system temp very hot, so static pressure might need to be way higher,, as you have seen 80 over 45, etc. This is where an infarred gun is really handy for charging. Fix that leak. and charge to proper amount. Remember overcharging hinders cooling. So does too much oil. Don't add oil unless you find an obvious oily leak. And remember, a little goes a long way. Further thought indicates that a restriction is possible depending on high pressure readings. Last edited by ScoT Frenzel; 05-20-2010 at 08:10 PM. |
| Recent General Rodding Tech posts with photos |
| To leave or keep A/C | chevyguy | General Rodding Tech | 13 | 08-14-2010 04:06 PM |
| Underhood air compressor from A/C parts | F&J | Garage - Tools | 4 | 07-25-2008 08:56 PM |
| A/C belt | mitmaks | Engine | 2 | 08-02-2007 05:27 AM |
| Should I remove my A/c | 1970Chevy | General Rodding Tech | 2 | 07-08-2007 10:22 AM |
| A/C question | Paco | Engine | 1 | 06-03-2002 07:01 PM |
