A/C line crimping tool recommendation. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2007, 12:25 PM
brian0605's Avatar
mostly confused
Last journal entry:
I need to crimp up all of my A/C lines. I cut everything to length, routed it like I wanted it and pulled it all back off the car. I went back over to NAPA where I bought the hose and asked the guy behind the counter (who happened to be the manager) if he could crimp them up? Well I felt like I had walked into an auto zone.UH UH YEAH I think I can crimp that UH UH. He fumbled his way through one and couldn't figure out which die to use next so I just gave up and left. Anyway does anyone have a source to buy a hand crimping tool?? Thanks in advance!! Brian
Old 06-18-2007, 12:51 PM
302 Z28's Avatar
Those tools can be a bit pricey, running about $300. Rather than buy one why don't you just go to a firm that makes up hydraulic hose. I had used a hand tool a number of years ago and it worked OK, but on my 34 I took the hoses to a hydraulic shop and the crimps looked much better than with the hand tool.
Vince
Old 06-18-2007, 12:55 PM
What kind of fittings are you using? The barb type with the ferrule that comes off the fitting? If you're using that type, I have a crimper. I say that because I see you're location is listed as central Mississippi. I'm in Vicksburg.
D.Cool
Old 06-19-2007, 09:22 AM
brian0605's Avatar
mostly confused
Last journal entry:
Thanks for the offer, I contacted my local Carquest and they did it for me for free!!!! I tipped the parts guy a 5 spot for his trouble and will certainly remember the generosity of Carquest when it comes time to buy some more parts!! 302 z28 I did do a little research and found a crimper that will do #6,#8,#10,#12 lines for 150$. from what I have read they are an improvement over tools of a few years ago. I also found a master set for upwards of 500$ . Think I'll pass on that. Brian
In Line Air Tool Oiler Kampr Garage - Tools 2 11-29-2006 06:27 PM
brake line update 61bone Suspension - Brakes - Steering 5 07-07-2005 05:42 AM
Air Line recommendation rod kent Hotrodders' Lounge 3 01-27-2005 03:20 PM
Body Line Man586 Body - Exterior 6 08-20-2004 09:24 AM
ford fuel line coupling tool tnoftsger Engine 2 02-18-2004 07:31 PM
