a/c not working - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2010, 05:36 PM
a/c not working
hey, I have a 56 dodge truck with a 305. a/c, power brakes
ok so yesterday the a/c stopped blowing I checked the fusses and their all good, non blown. so my a/c is turned on through a toggle switch one blue wire and a red wire the blue wire goes connected to this, am assuming relay? do you think it could be the culprit? anybody know the name of it so I could get it at autozone. thanks
sorry for the bad picture.
Old 08-08-2010, 06:48 PM
LATECH's Avatar
that is a gm high blower relay.(the silver one) I am assuming the fan quit working?
Old 08-09-2010, 09:26 PM
New Member
These recommendations depend actually on the height and size of the room the season and the activity taking place in the room.
facebook Apps
Old 08-11-2010, 07:11 PM
replaced that relay today and still no a/c. the fuse is still good any other things I should check?
Old 08-11-2010, 07:38 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
The next step would be to check and see if you have power to the fan motor with the unit on. If you have 12v, I would suspect the blower motor. You could disconnect the blower motor from the relay and wire it direct to the battery to see if it works. If it don't work wired direct, it's the motor. Make sure all your grounds are good also. A bad ground will cause all sorts of problems.
sbc over heating with a/c 85 vette Engine 15 04-05-2008 06:08 PM
1965 T-Bird A/C Clutch atlas4141 Electrical 1 08-14-2005 12:30 AM
Aftermarket A/C Camaro76 Engine 0 06-25-2004 11:23 PM
Overheating and a/c question.. Meangreen General Rodding Tech 28 06-23-2004 10:02 PM
a/c in '36 fatkoop Interior 11 12-03-2002 02:01 PM
