'c" notch question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2006, 05:57 PM
'c" notch question
i am building a 48 f1 ford truck with a camero front clip. I need some help with "c" notches for rear axle clearance - pictures, instructions or both. i can not find any information. help|
Old 11-24-2006, 10:18 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Check these links out:
http://www.hotrodders.com/forum/jour...ge=1&reverse=1
http://jalopyjournal.com/forum/showthread.php?t=135430
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 11-24-2006, 11:04 PM
Here's the best trick in the world.
For all my companies smaller notches we use a simple trick.
Take a piece of 5" pipe(1/4" thick or better), cut a section 3" long. Then cut this section in half to make two half circles. -o- to C
Hold the half circle up to the frame rail making sure the bottom is flush. Mark it all the way around. Next, cut the section out. Then, hold your half circle in the area and clean up your cuts to make a smooth fit easier to weld. Then just weld in your half circle of pipe, both sides: inside and out. this is frame rail so pay particular attention to your welds, make sure you get a good weld.
Hope this suggestion helps.
Jay Josey
Old 11-24-2006, 11:41 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I've done one and it turned out pretty well. It was for an old trailer frame that we lowered to make a flatbed, so if it held up for one axle and 20,000 lbs, it should hold up for a vehicle.
I simply fabricated and welded the C-notch in place first. I found some 2" x 4" square tubing that matched the profile of the original frame. I cut risers with 22.5* angles top and bottom and a cross piece with corresponding angles. I cleaned off the top of the frame, welded the C-notch in place with a good 220v MIG making sure to get really good penetration, then I cut out the original frame between. The original frame was just a channel, so I firmed things up by boxing the frame about a foot in front and behind the notch
Old 11-25-2006, 06:28 AM
'c' Notch Answers
Thanks All You Guys For Tour Answers And Pictures. Think I Can
Make A "c" Notch Now.
Old 11-25-2006, 10:21 AM
powerrodsmike's Avatar
Wiki Edits: 161
If I do a c notch in a car frame I don't cut any more than half of the height out of the frame without adding something to the top to put the strength back in. I usually add a plate to the inside of the frame that goes about 4 inches on either side of the notch and rosette weld it to the inside of the frame.
This would apply to the cut out and pipe filled method described in post 3. On an F1 channel steel frame the "C" notched section needs to be boxed at least 10 inches fore and aft of the notch if you use the "pipe filled" method.
The "C" frame method like curtis73 described keeps the strength in by design.
Later, mikey
BE different....ACT normal.
Old 11-25-2006, 05:28 PM
"c" notch answer
powerrodsmike. thanks for the pointers. i will box in the frame. do you have any way to learn how much clearance the "c" notch needs to provide?
Old 11-25-2006, 08:01 PM
C-Notch
I,ve done several 32 ford frames not sure what your frame looks like, If rails are not paralell like the 32 ford rails you must determine a centerline and cut accordingly.
Old 12-04-2006, 06:42 PM
pickler91's Avatar
the future of hotrodding
check the lowrider companys like Thorbecke Brothers, they sell universal C-notches and specific ones, if you call them they'll build you anything you want. they specialize in air-ride systems for those Mini-Trucks. one of the local garages has been building them and they currently have a built 55 ford pickup, its lowered and tubbed, and has a nice c-notch for $6500. ill get a diagram of a notch for you if i can find the one i had.
Dillon
Old 12-04-2006, 06:44 PM
pickler91's Avatar
heres the link to Thorbecke Brothers
http://www.suicidedoors.com/Notches.php
383 stroker 73monte Engine 13 05-11-2016 12:17 PM
Question about vehical weight and engine question Thuggishruggish3000 Engine 12 03-24-2011 06:22 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 08:35 AM
Switching to 200R Tranny question Gundarak Transmission - Rearend 4 12-05-2003 09:00 PM
nitrous 69BiRd Engine 2 11-28-2003 11:33 PM
