A/C problem..I think it's the compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2006, 01:08 PM
RodFather's Avatar
I smell like a hotrod!
Last journal entry: windshield
I have a 2000 tahoe, and at idle it will start blowing hot air. I cools up when driving. I went, and bought freon with a gauge on it. It says the pressure should be 25-45 psi....the gauge says I have 98psi in there. Could the compressor be messed up leading to the rise in Freon pressure? At idle the cluth is not ingaged on the compressor.
Old 08-11-2006, 01:26 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Is the 98 psi with the engine running? You should be seeing the pressure drop until it reaches 32-35 psi on the low side then the compressor will cycle off, so on and so on. If you are seeing 98psi running I would say you have an overcharged system or the compressor is bad. Did you add freon?
Steve
Old 08-11-2006, 01:29 PM
RodFather's Avatar
No I was afraid to add freon. It was reading 98 PSI with the A/C on high, but the compressor clutch didn't appear to be on. Driving down the road it will cool down a little.
Old 08-11-2006, 01:49 PM
1931 steve's Avatar
Wiki Edits: 4
Does the A/c compressor cycle at all. Can you jump the low pressure switch to see if the compressor is working?
Steve
Old 08-11-2006, 01:50 PM
RodFather's Avatar
I'll try that in a little while.
Old 08-11-2006, 01:59 PM
1931 steve's Avatar
Wiki Edits: 4
Don't worry about what the pressure is until you have the compressor working.
Steve
Old 08-11-2006, 03:50 PM
302 Z28's Avatar
I agree, the pressure readings do not mean squat if the compressor is not running.
Vince
Old 08-19-2006, 11:54 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Too much pressure. Period. Check the static pressure after the vehicle has been turned off for 10 minutes. It should be 50 max.
The over-pressure switch probably has the compressor locked off until driving down the road cools the system and makes the pressure drop into the safe zone.
You should check for a defective fan clutch not pulling enough air at low speeds.
I would remove all the freon and reinstall correctly. I recommend www.duracool.com which cools much better than 134 or 12 and is fully guaranteed in writing not to damage the system.
www.readershotrods.com see your ride?
Old 08-24-2006, 04:45 AM
Last journal entry: Robs34 - Done my dash
Air in the system will increase pressure on both sides, whenever you top up and you find this has happened you should discharge, evacuate for an hour and refill. Add a little oil too.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
air compressor maintenance CaPrI_MaN Garage - Tools 8 10-04-2006 10:14 PM
Compressor Water Problem MI2600 Garage - Tools 8 12-26-2004 06:54 PM
A/C question Paco Engine 1 06-03-2002 07:01 PM
a/c bracket? compressor? oldcarguy85 Engine 3 04-23-2002 05:14 PM
