A/C question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2005, 06:01 PM
A/C question
O.K. Ive installed A/C, everything works great! I have electric fan which I have hooked up with a relay to my manual switch that goes to my compressor. Do I have to have my compressor hooked all the time with my 12volt feed when I turn it on? Because if not then I will take it off my manual switch because I really don't need the fan all the time! As of now everytime I turn on my A/C I turn on my fan (which is how I get my 12volt feed) Advise, thanks Dana
Old 08-28-2005, 07:46 PM
rrmccabe's Avatar
GM Muscle
What kind of compressor is this?
As a rule A/C compressors are not fed with 12 volts constant and are just cycled with a pressure switch. If your compressor has an internal pressure switch I guess you have to have 12 volts on it all the time.
Rich
Old 08-28-2005, 08:31 PM
re:AC question
I've always used a fan that is controlled by engine temp, manual override, and then from the binary switch on the drier to the fan relay- that way the fan comes on whenever the compressor is cycling. I've read that electric fans use minimal current once you're moving along. Bill
Basic A/C Question MI2600 General Rodding Tech 3 06-14-2005 07:42 AM
A/C Question DoubleVision Electrical 7 08-30-2004 11:05 AM
Sanden a/c compressor question zonk General Rodding Tech 2 07-13-2004 12:54 PM
Overheating and a/c question.. Meangreen General Rodding Tech 28 06-23-2004 11:02 PM
A/C question Paco Engine 1 06-03-2002 08:01 PM
