A/C recharge - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 08-01-2012, 09:11 AM
302 Z28's Avatar
Originally Posted by LATECH View Post
You would be suprised how many people dont know about running the HVAC on Recirc. If only they would read the owners manual...
Exactly, when I was working as a mechaic that is how I solved quite a few A/C problems.
Vince
  #32 (permalink)
Old 08-04-2012, 02:01 PM
mitmaks's Avatar
Last journal entry: Grille
No problem. O rings wont know the difference.
I would however see if there is an exspansion valve available for the R134.
Check to see if a 94 valve will fit, then use it.It is better calibrated for 134a . It will cool a little better, and more importantly keep the head pressure (high pressure side in the compressor) down so the compressor doesnt work so hard, and lives longer.
If you have O rings to replace the areas that you are dissasembling , use them. If not, as long as they are pliable, and are not deformed to the shape they are when installed under pressure, use them.When an o ring takes a set to a shape other than round, either circumferentially, or radialy they are NOT OK. Naturaly any O ring that is cut or split is a no brainer. Hope this helps.
Do I have to remove all the old oil (mineral) from system/AC compressor or would PAG be fine in it?
  #33 (permalink)
Old 08-04-2012, 06:22 PM
LATECH's Avatar
Last journal entry: New Gas Tank
Ideally you would flush it out and get it clean. Synthetic PAG mixes with ALL oils , that takes all the worry out. get system clean as possible, and assemble. It will be good to go.
Fact is stranger than Fiction
  #34 (permalink)
Old 08-04-2012, 07:02 PM
mitmaks's Avatar
I have another car and high pressure side needle is vibrating. What could cause this?
  #35 (permalink)
Old 08-04-2012, 07:50 PM
LATECH's Avatar
compressor problem.. Like a weak cylinder, or a faulty reed plate.
91 olds air conditioning recharge, add a fan or compressor fumplet General Rodding Tech 7 12-18-2012 04:39 PM
How to recharge my own R-12 fluid for the AC? Rockworthy General Rodding Tech 8 05-19-2011 08:48 PM
need a/c opinion, recharge?? Walker Engine 4 08-07-2003 09:40 PM
