A/C shuts causes engine to stall - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2011, 12:23 PM
1969chevyss's Avatar
I have a 69 caprice with a 350 4bbl and a/c. Ac blows good but when I'm driving and come to a light it starts to stall and gen lights pops on so I shut the ac off and everything goes back to normal. I have a edelbrock 1406, and noticed that edelbrock sells an idle compensator solenoid that maintains a certain idle when the ac is switched on, this little thingy is close to 100 bucks. Can I just bump up the idle on the carb a few hundrend rpms and this will do the trick, and if I do this will I have to make any other adjustments such as fuel mixture or fuel regulator adjustments. Any help would be greatly appreciated.
Old 08-22-2011, 12:37 PM
327NUT's Avatar
What you're suggesting is a band-aid approach.......but if you don't want to spend the extra money then yes you can dial up the idle. I would only turn it up just enough to keep the engine from stalling because when the ac is off the engine will basically free wheel. I know this is not the most "technical" way of solving the problem but it will help until you can afford the correct solution.
Old 08-22-2011, 12:42 PM
I dont mind spending the money if this is what will solve the problem. Will this solve the problem.
Old 08-22-2011, 12:56 PM
sbchevfreak's Avatar
Licenced Automotive Technician
In a word, yes.
Old 08-22-2011, 12:57 PM
Great thanks for the info. I will order it from Summit today. Awesome website.
1998 Olds Achieva Engine Shuts off. Jakep51 Engine 3 05-23-2011 09:56 AM
Engine stall Hellalive89 Engine 6 04-30-2011 12:18 PM
Engine Stall aholcombe Engine 4 04-07-2011 05:32 PM
engine stall adrock430 Engine 1 06-13-2005 08:54 PM
car shuts off zeak108 Engine 5 01-24-2003 05:44 AM
