A/C swap 68 Chevelle - 73 Monte Carlo ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2008, 09:04 PM
I want to pull a factory AC unit from a 68 Chevelle,
and put it in my 73 Monte Carlo. Is it possible?
The monte's AC has long since been removed,
and all thats left is the evaporator core.
It looks identical to the unit in the Chevelle.
I appreciate any advise that y'all migh have on this.
Old 08-02-2008, 11:17 AM
DanTwoLakes's Avatar
Wiki Edits: 22
This is not really a question for the interior forum, so I'm going to move your post to General Rodding Tech.
Dan
Old 08-02-2008, 11:48 AM
Usually the 68-72 A-body parts do not interchange with those from the 73-77 cars.
Old 08-02-2008, 12:28 PM
What exactly do you mean by "pull a factory AC unit from a 68 Chevelle"?
The GM compressor and brackets are probably the same (big, heavy A6), and the evaporator and condenser will be similar, but its hard to tell whether any other parts will fit in your car. The two years may also use a different type of pressure control mechanism ('73 is probably fixed orifice tube; not sure about a '68, but its probably a TXV).
It should be relatively easy to find a condenser, accumulator, compressor and hoses for your '68 from most parts stores. If you need a Thermostatic Expansion Valve (TXV), it may be a little harder to find a direct replacement.
Bruce
ok lets see how many monte carlo people agree monte mike Hotrodders' Lounge 25 11-19-2006 04:09 PM
Monte Carlo info website. schnitz Hotrodding Basics 1 10-19-2006 03:48 PM
monte carlo engine montecarlogb Engine 1 05-08-2006 08:08 PM
HEI in '73 Monte Carlo Seon Engine 4 11-10-2002 04:58 PM
'73 Monte Carlo died Seon Engine 4 10-31-2002 07:42 PM
