I have a 1969 c10 and I want to put the fuel tank under the bed. the tank that I am thinking about is from LMC with the side fill. Any suggestions on where/how to mount the filler neck. Thanks
It appears that a tank from 73-87 is what you're looking into. I believe I would look in the junkyard and get all of the pieces need to mount the tank and take pictures of how and exactly where it is mounted.
Not quite correct. The Suburbans had theirs mounted under the bed, and filled at the side. The filler neck does not interfere with hauling anything, as it's directed below the deck surface. The small metal hump at the left rear is back further than the inner wheelwell, so it can't interfere. You can see it in this picture of my '69 Burb:
I'd guess that LMC sells a later tank, and most likely the later fuel neck filler setup. Most likely uses a rubber grommet around the neck outside like my Suburban, and then whatever chrome cap you want. Might also buy a fuel door assembly, if you want a door over thhe filler, butt I think the simple cap looks better. Couldn't find a close up pic, but this is where the Suburban filler sits:
i used a fuel door on my 58, you have to get a little creative in positioning the door
i've also seen the original filler neck and grommet relocated to the rear fender
best choice would be a reman tank from the suburban/panel
on a lower truck this fuel door is way to low, should have put the filler door on top of the fender
Can't find the pic but I ran the filler behind the rear side light marker and put the marker on a hinge, so to fill you flipped out the side light marker and put the fuel in behind it.
I can't picture that in my mind? The marker light is so small, I can't see how it would fit most modern nozzles without having some extra metal open around the side marker light?
I have a fleetside. I like what you did I am thinking of going to put the filler neck between the inner wall and the outer fender. And fill it inside the bed.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
