Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - c2500 oil pressure
Old 10-07-2008, 01:29 AM
SSedan64's Avatar
SSedan64 SSedan64 is offline
These have a safety feature. If the oil pressure drops below a certain psi. it cuts power to the fuel pump. May be bad oil pressure sending units like was mentioned above. Depending on what type sender you have N/O or N/C you may be able to just unplug the sender and see if it will run.
