c2500 oil pressure - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2008, 08:53 AM
c2500 oil pressure
I have A 1996 2500 chevy suburban with a 454 motor.
I was driveing up A steep grade when I Lost oil pressure and all power.
It will start but has no pressure and will shut off if put in gear.
The oil Level And Filter are fine. I have a C3500 Chevy with a 350 that is dooing the same thing. Help!!!
Old 10-06-2008, 10:58 AM
Bench racer
What RPM is it idling at? If you give it throttle in park does the oil pressure come up?
Keep in mind that if you really have no oil flow you are damaging the engine by running it!
BTW, if you've had this happen to two trucks, remind me not to let you borrow mine
Old 10-06-2008, 05:28 PM
T-bucket23's Avatar
Wiki Edits: 26
What kind of filters are you using
Chet
Old 10-06-2008, 05:34 PM
GMC boogie's Avatar
The oil pressure sensors on these trucks are known to go bad,give faulty readings,etc.
I would install a mechanical gauge just to verify oil pressure.
Old 10-07-2008, 02:29 AM
SSedan64's Avatar
These have a safety feature. If the oil pressure drops below a certain psi. it cuts power to the fuel pump. May be bad oil pressure sending units like was mentioned above. Depending on what type sender you have N/O or N/C you may be able to just unplug the sender and see if it will run.
Old 10-07-2008, 09:37 AM
c2500 oil pressure
If you idle up the pressure goes up 2 or 3 PSI
I have been using Fram Filters
Old 10-07-2008, 11:00 AM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Did both trucks start doing this at the same time, or say within a week, or so?
Old 10-07-2008, 11:39 AM
King of my Man-cave.
Change the filters and see what happens.
Did this happen shortly after an oil/filter change?
Fram filters are known for causing pressure problems.
tom
Old 10-07-2008, 11:56 AM
Have an interesting comment to add. A DHL leased operator had a diesel cube van that he got towed into the GM dealer due to loss of oil pressure. They told him the motor will need to be tore down and inspected for trouble........big expense.
He ended up buying another cube van seeing his had a lot of miles on it. He sold his old one locally to a guy he new for $1,000.00.
A couple days later he gets a call from this guy and said the van runs fine............was just an oil pressure sending unit.
Nice diagnosis from the dealer.
Old 10-10-2008, 06:47 AM
c2500 oil pressure
The trucks messed up about 3 months apart.
I Changed the oil and unpluged the sending unit then started
the 3500. It ran ok, so I pluged it back in and it runs fine now.
Iplan to do the same to the 2500 next and see what it does.
Old 10-11-2008, 04:01 PM
I might be a bit cynical after all these years,
but,
IMO 80% of the shops are either incompetent or just plain THEIVES.
My $1200-1500 transmission overhaul estimate from 5 different shops finally only cost me $2 for a broken plastic bushing to fix it.
I bought that honest transmission man and his wife steak dinners for his free advice= and had to MAKE him take the money.
"A good man is worth his hire"
Old 10-15-2008, 06:42 AM
c2500 Oil Pressure
Well The c2500 worked when I unplugged the oil sensor
but I can not get the sensor out. Is there some trick
or special tool to remove it? I tried going from the bottom
and the from the top, I just cant get any tool on it.
Oil Pressure questions RObs71Nova Engine 22 05-02-2009 02:45 AM
Is it no good to have a High volume oil pump? Calderone Engine 17 01-31-2008 06:26 PM
another oil pressure question timemachine Engine 2 09-26-2007 10:26 PM
Oil pressure loss SB Chevy Finmike Engine 30 06-12-2004 11:27 AM
Low oil pressure at idle on rebuilt 350 Palmtrees57 Engine 25 02-13-2004 11:30 AM
