C4 (1984) Corvette Tranny - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2012, 07:13 PM
Heys guys do you know if I can take any regular GM manual tranny and put it in my automatic 84 vette. Im guessin I would have to modify the crossmember and get a different driveshaft.
Old 04-21-2012, 04:09 PM
68NovaSS's Avatar
Wiki Edits: 9
If you can find a bell housing that matches the trans bolt pattern and is the correct depth for the input shaft, clutch release arm and associated parts, sure. But keep in mind if you have a console, chances of the shifter and linkage being in the right spot may be an issue, regardless, you'll need a console out of a manual vette, or none. You'll also need all the pedal pieces, hangers, linkages, and the block/frame pivot ball mounts for the clutch linkage, crank input shaft bearing/bushing to match the input shaft diameter. If the setup you choose is hydraulic, that's a whole different story.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
1984 corvette saltbob Transmission - Rearend 11 02-28-2012 05:41 PM
1984 corvette jkendrick Introduce Yourself 4 01-07-2010 03:24 PM
1984 Chevy Corvette tanjabrooks85@yahoo. Introduce Yourself 2 12-07-2009 05:31 PM
1984 corvette defo98 Engine 4 07-31-2007 12:43 AM
1984 Corvette!! Help Anyone!! 67goat Body - Exterior 6 10-19-2005 06:44 AM
