C4/AOD width dimensions - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2008, 03:10 PM
Everywhere I see length measurements of the C4 and AOD - I would like to learn the width differences of the C4 and AOD trans. My current AOD barely squeezes in between my headers/collectors - I'm hoping the C4 that will go in my car next week will be skinnier width-wise! Anyone know the differences in C4 versus AOD dimensions?
Old 06-05-2008, 06:00 PM
FEDDO's Avatar
both are the same width at the bell housing. You might want to go to the smaller 157 tooth bell. that is if you have a 164 now.I think the aod is 164.that moves the starter a little.
Old 06-05-2008, 07:39 PM
Why a 157 tooth bellhousing? It's smaller?
Old 06-05-2008, 09:30 PM
Crosley's Avatar
Wiki Edits: 1659
the c-4 is narrower than the AOD... I do not have measurements , but it is narrower
35 Ford Pickup cab and frame width?? Super Chevy General Rodding Tech 6 01-19-2009 12:36 AM
dimensions needed Bill-E-BoB Body - Exterior 9 08-23-2007 07:23 PM
Tire width and rim width??? voodoosurfer General Rodding Tech 2 11-09-2005 12:54 AM
SS stripe dimensions? HELP ME M&M CUSTOM Body - Exterior 13 06-26-2005 05:55 AM
measuring rim width cboy General Rodding Tech 5 11-12-2004 09:44 PM
