C4 or C6 swap instead of the 93 o/d - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2008, 06:03 PM
"70" Cougar's Avatar
Meat-Head Extroidenaire
Well my friend has had some bad luck with his 93 F150 overdrive trany ( its 2 wheel drive) he would like to change it out for a C4 or C6 which one would be the better choice. Also what would be involved in the swap?
thanks
bill
Old 02-27-2008, 06:27 PM
Gonna be tough to put a three speed in there. The PCM is programmed for the overdrive and its proper operation. Better off fixing the trans that's there....
Old 02-27-2008, 07:55 PM
ok ok.. dumb it down a bit for me.... the motor wont work right if the trans isnt jiving with the brain box?
Old 02-27-2008, 08:06 PM
swap the trans ,the cam ,the intake to a carb type
drive shaft ,speedo ,
yea rebuild the trans best
Old 02-28-2008, 06:12 AM
I'll let him know folks.
thanks alot.
bill C
Old 02-28-2008, 09:18 AM
about the only thing it would do is set a trans fault code, not affect engine operation.You always just grab the pcm out of a manual trans version then it wouldn't know or care about the tranny.
C4 tailshaft swap? 70chevyc10 Transmission - Rearend 1 07-06-2007 06:49 PM
C6 specs versus C4 k2mooch Transmission - Rearend 2 05-19-2004 10:06 AM
AOD to C6 Swap Discipher Transmission - Rearend 1 01-13-2003 10:57 AM
c4 trans swap FASTFORD Transmission - Rearend 3 05-07-2002 11:11 AM
