Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - C4 ford trans not going into 3rd
Old 04-20-2006, 08:11 AM
transmandan's Avatar
transmandan transmandan is offline
Automatic Trans Specialist
You need to check the governor it sounds like its sticking (remove tail shaft housing) its held on by four small bolts remove it and see if the weights are sticking or stuck when cold
