Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - C4 ford trans not going into 3rd
Old 04-20-2006, 11:33 AM
Ed ke6bnl Ed ke6bnl is offline
Originally Posted by transmandan
You need to check the governor it sounds like its sticking (remove tail shaft housing) its held on by four small bolts remove it and see if the weights are sticking or stuck when cold
Thanks for the message, if they are sticky can I just lube and work them back and forth to free them up,and do I need to drain the pan first then remove the tail shaft. thanks Ed
