Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - C4 ford trans not going into 3rd
Old 04-20-2006, 12:14 PM
Ed ke6bnl Ed ke6bnl is offline
Originally Posted by transmandan
No need to drain the fluid just remove the govenor and clean it and lube it with wd 40 or trans fluid and make sure the valves work back and forth and i think it will be just fine
Hi Dan I removed the tailhousing and the govenor, and the weights are free as can be so it seem like I am in for a rebuilt, was worth a try and what a project my boy but dual exhaust and sounded good but sounds like a lot of extra work to do the job know. Intresting experience though ED
