Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - C4 ford trans not going into 3rd
Old 04-20-2006, 12:23 PM
matt167 matt167 is offline
Wiki Edits: 31
u have the 200 I6, if so get a set of FSPP headders from www.fordsix.com, and get a compleate stock exhaust kit for a v8 mustang of the same year ( will be 2" ), seems like the kit for a K code 289 would work well, you will need a short custom pipe to connect the driver side pipe to the headder but that's it, all that would entale is cutting the driver side pipe off a little and get some tubing of the right diamater, and have it bent so it fits.
