Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - C4 ford trans not going into 3rd
Old 04-20-2006, 03:53 PM
Ed ke6bnl Ed ke6bnl is offline
Originally Posted by transmandan
If the governor is ok the direct clutch piston seals are hard and when it gets warm they seal and work ok when it cools off it does what yours is doing when you take it apart see if the seals in that clutch drum break like sticks this unit is very easy to rebuild if you have any questions just let me know
Well I am now only a 3 torque converter bolts and about 3 bell housing and the starter from removing the trans. I work graveyard and tomorrow I will finish up removing it. thanks for all your suggestion I found a rebuilt trans and converter real reasonable and will try to get it next week. Nice to have the help out there Ed ke6bnl
