You need to check the governor it sounds like its sticking (remove tail shaft housing) its held on by four small bolts remove it and see if the weights are sticking or stuck when cold
u have the 200 I6, if so get a set of FSPP headders from www.fordsix.com, and get a compleate stock exhaust kit for a v8 mustang of the same year ( will be 2" ), seems like the kit for a K code 289 would work well, you will need a short custom pipe to connect the driver side pipe to the headder but that's it, all that would entale is cutting the driver side pipe off a little and get some tubing of the right diamater, and have it bent so it fits.
If the governor is ok the direct clutch piston seals are hard and when it gets warm they seal and work ok when it cools off it does what yours is doing when you take it apart see if the seals in that clutch drum break like sticks this unit is very easy to rebuild if you have any questions just let me know
Thanks I will do just that. Ed ke6bnl |
c4
how is reverse when cold or first started? if reverse is good try valve body replacement 2-3 shift valve may be sticking. dont over lool the small things, what the history of the car has tranny ever been rebuilt or should I say when was the last rebuild if you know??
| will a 427 ford engine bolt up to a c-6 4x4 trans. | farmguy_74 | Introduce Yourself | 2 | 02-20-2006 06:20 PM |
| Trans for a Ford 460 | wildtaxi21 | Transmission - Rearend | 0 | 01-29-2006 09:36 PM |
| AXOD Ford trans rebuild advice. | 4 Jaw Chuck | Transmission - Rearend | 22 | 03-16-2004 05:37 PM |
| Trans for a 350 ramjet in 37 ford street rod | cng41 | Transmission - Rearend | 0 | 09-16-2003 12:31 PM |
| 1964 Ford Falcon Trans slip into 2nd | whytyewytche | Transmission - Rearend | 0 | 11-27-2001 05:13 AM |
