c4 irs experts - need help! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-09-2008, 07:42 AM
Here is some info I put in another forum entry a while ago.........
Maybe I can help with some of the angles and measurements. I have a 86 vette with the Dana 44. Here are some angles/measurements (at least as to how it pertains to being installed in my stock vette).
The car has been sitting on a fairly level garage floor for about 4 days without moving so I assume it is pretty well settled.
Centerline of outside of rims to ground 12-1/4" measured at a width of 68" (this gives you a reference point).
Bottom of differential case to ground 8-3/4" measured at rear of case on center line.
Half shafts pointing down toward outside 4 degrees.
Frame mounting brackets pointing back at 66 degrees. This could even be 67 since it looks like the floor slopes to the rear of the car about 4/10 of a degree in 4 feet.
Top arm pivot point on bracket 16-3/4" centerline of bolt to ground
Bottom arm pivot point on bracket 13-1/8" centerline to ground
Spring hangs down about 2.7 degrees toward outside
All measurements done with a tape measure and a Craftsman 8" digital level.
  #17 (permalink)
Old 09-09-2008, 08:32 AM
thanks - yeah i'm hoping i can just flip those to the other side of the bracket.
i'll try that after work today
  #18 (permalink)
Old 09-14-2008, 01:37 PM
just an update here to close out my issue.
i ended up lowering the diff, which helped a ton and then also when to an adjustable rod for the dog bones. So far with my limited test runs, it seems to have solved the issue and the car feels silky smooth
everything was off the shelf components from rodendsupply.com and came within a day or two. If anyone wants to know the details, let me know
  #19 (permalink)
Old 09-14-2008, 01:54 PM
32v 32v is offline
your welcome
Corvette C4 IRS Suspension Geometry? Stovebolter Suspension - Brakes - Steering 4 05-12-2014 05:40 PM
Narrowed C4 IRS.....camber question Stovebolter Suspension - Brakes - Steering 0 08-05-2008 06:21 AM
Narrowing a C4 IRS....Wow....my head hurts! Stovebolter Transmission - Rearend 21 05-01-2008 10:49 AM
C4 Corvette IRS Stovebolter Transmission - Rearend 5 02-25-2008 06:26 AM
IRS kits, C4 'vette, Heidts, or Kugel???? tatsukun Transmission - Rearend 3 01-08-2008 07:09 PM
