C4 kickdown - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2007, 03:16 PM
'57 Fairlane
C4 kickdown
Is it very important to connect the kickdown system to ford C4 trans? I have the vacuum in place, but no linkage for mechanical kick.
Old 08-28-2007, 09:11 AM
Wiki Edits: 27
important yes
Find one at the wrecking yard and install-adjust according to the factory specs revving the engine without the propper pressure can wear parts
Ford C-4 Kickdown Question Z-Money Pit Transmission - Rearend 2 10-11-2005 02:34 PM
Replacing C4 with AOD Mustang50Clay Transmission - Rearend 5 05-04-2004 05:24 PM
Input shaft conversion for C4 k2mooch Transmission - Rearend 8 12-29-2003 10:36 AM
a/t kickdown cable adjustment maddmaxx Engine 4 10-27-2003 08:04 AM
Adjusting Kickdown horvath Transmission - Rearend 4 05-17-2003 04:14 PM
