c4 leaks - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2004, 11:15 PM
57custom's Avatar
c4 leaks
have a c4 in 67 mustang, it drives good ,shifts good,but after i t is parked for a day or two it starts to leak fluid. installed a new pan, new seal around shifter where it goes thru case . no help. any ideas
Old 04-29-2004, 11:43 PM
1957ford's Avatar
If it don't go Add Horsepower!
Front pump seal?
Old 04-29-2004, 11:46 PM
57Custom,
Take a look at the speedo cable. It may need an "o" ring.
Good Luck
Scholman
