C4 problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2007, 04:45 AM
C4 problem
Ok I just replaced the servo on my c4 tranny with a aftermarket one. The good news is my 2-3 flare is gone, the bad news is it now wont shift into 2nd until almost 5000 rpms. The tranny is in a 65 Mustang fastback. Thanks in advance for any help.
Old 10-16-2007, 06:14 AM
Irelands child's Avatar
Did you reconnect the vacuum line to the modulator(right side of tranny near the bottom) and to the correct vacuum port??
Irelands child
Old 10-16-2007, 06:24 AM
Yep sure did. I might try adjusting it though, along with the low/reverse band. What i dont understand is how changing the intermediate servo would effect the 1-2 shift.
Old 10-16-2007, 06:59 AM
There is also an allen wrench adjustment on the modulator as well - thru the vacuum port
Irelands child
Old 10-16-2007, 11:20 AM
It was the the bands. I adjusted both the bands and now she shifts like a dream. Thank you for the info and fast reply Irelands Child!!!!
Old 10-16-2007, 12:32 PM
Is this aluminum servo cover and innards what you replaced - kinda hard to see with the rest of the claptrap
Irelands child
Old 10-16-2007, 04:19 PM
Yep thats the one. Its no fun with the tranny in the car.
Old 10-16-2007, 06:08 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
You changed the 2nd gear servo with the trans in the car?
Did you drop the trans pan and valve body to change this servo , then re-install the band struts?
Old 10-17-2007, 01:50 PM
Just dropped the pan and valve body
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 11 07-19-2007 08:07 PM
I'm having a primer adhesion problem on one door Ripped Body - Exterior 10 06-08-2007 12:45 PM
96 Plymouth Voyager spark problem? baddbob Electrical 12 05-19-2007 03:44 PM
Puzzling temperature problem on the hemi solved Centerline Engine 2 11-26-2004 03:48 PM
Replacing C4 with AOD Mustang50Clay Transmission - Rearend 5 05-04-2004 05:24 PM
