Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - C4 Shift issues
Thread: C4 Shift issues
Old 01-12-2013, 06:59 PM
rick 427's Avatar
rick 427 rick 427 is offline
Last journal entry: The 32's
Another possibility...You might also want to check the carb to trans kickdown rod adjustment...if its adjusted to where its burying the KD valve in the valve body on WOT..then it would stay in 1st until you let up on the pedal,and in turn,relaxing that valve,allowing it then to shift into 2nd.
