C4 Shift issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2013, 11:48 PM
kleen56's Avatar
C4 Shift issues
I have a 68 C4 transmission on my SBF. I'm running a B&M quick shifter. Not sure where to look to fix my problem which is this. The transmission shifts fine when normal driving. If I put it in 1st gear and WOT, then click it to 2nd gear, it won't shift instantly into 2nd. If I back off the gas pedal, then it will shift hard into 2nd. If I stay on WOT, 3rd gear works fine. Is there an adjustment for this issue from 1st to 2nd with WOT, or what could be the issue?
Old 01-12-2013, 10:52 AM
pricesgarages's Avatar
the band may need adjusted or the front servo seals are bad
Old 01-12-2013, 06:59 PM
rick 427's Avatar
Last journal entry: 33 WILLYS
Another possibility...You might also want to check the carb to trans kickdown rod adjustment...if its adjusted to where its burying the KD valve in the valve body on WOT..then it would stay in 1st until you let up on the pedal,and in turn,relaxing that valve,allowing it then to shift into 2nd.
Old 01-12-2013, 08:21 PM
kleen56's Avatar
I don't have a kick down linkage setup on my carb/ tranny. I'm going to try a band adjustment first. If I leave it in Drive, the transmission will shift OK, it's when I manually go to 1st (L), rev up the rpms and drop it to 2nd gear. It won't shift and continues to rev up until I release the gas pedal. Maybe a vacuum problem with the modulator valve? I don't much about trannies, but I think it may be something I resolve without a tranny shop charging me $ to look at it.
Old 01-12-2013, 10:24 PM
rick 427's Avatar
Well then...I guess we can strike my last suggestion.....you offered up my next thought....I would 'T' the vacuum line to a gauge,and hold it in my hand ,and see what the vacuum is reading...you know the vacuum is right under normal driving,as the trans works good...but does something change under WOT?...and make sure ALL the vacuum lines under the hood,and at the modulator,are in good shape..Whats the history of this trans?...rebuilt,,stock,,never touched,etc.?
Old 01-13-2013, 12:04 AM
kleen56's Avatar
Thanks Rick 427, The vacuum reads at 15 lbs at idle which should still be enough for the transmission. As for the tranny? I have no info on it, because it was the tranny that came with my truck. It appears it may have been rebuilt at one point or someone painted the casing Ford blue. It's been acting like this for some time now. Time to fix it as it's pretty annoying when you jump on the gas pedal and then have to back off to get it to shift I like the C4, but may opt to replace it with an AOD. I've also noticed the problem has gotten worse after changing the rear gearing to 3.50 gears from the 2.80's that were in it. The engine screams, but what good is it if you can't bang 2nd gear?
Old 01-13-2013, 01:20 AM
rick 427's Avatar
Well...you should really be seeing 18-20 at idle...15 is low.
Old 01-13-2013, 02:41 PM
if you donot have the kick down hooked up it will not work correctly at wot
4L60E Shift and grind issues Aron1980 Transmission - Rearend 2 03-22-2011 10:49 AM
Turbo 350 Trans Shift/Slip issues CincyMuscle Transmission - Rearend 5 09-30-2009 08:17 PM
350 turbo shift issues. Heavychevy82 Transmission - Rearend 4 09-28-2009 09:58 PM
700r4 Shift issues David_TN Transmission - Rearend 1 04-13-2009 05:42 PM
my tranny wont shift hard even with shift kit notmrgoodwrench Transmission - Rearend 4 08-12-2003 07:10 PM
