C4 slip yoke clearance, side to side, runout. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2011, 02:59 AM
67Mustang Al.'s Avatar
Having a vibrating tailshaft at 20, 30 40 mph is not what i had hoped for after finally hitting the road with the 67. Car has standard springs, aluminium tailshaft with new joints front and rear, and balanced.
I lifted up the car today and put a dial gauge on the diff -end of the tail shaft and measured 30 thou run-out in one revolution with no movement in the universal.
The yoke sits out of the rear of the gearbox housing by 46 mm with rear axle sitting on two jack stands. When i grabbed hold of the front/gearbox universal joint and pulled up and down on it i could feel and see movement. I could measure 20 thou when i mounted a dial gauge on the polished section of the yoke. Is this within tolerance as i am thinking this will allow the shaft to spin out of round. Any thoughts appreciated.
Al.
Old 09-26-2011, 08:36 PM
SSedan64's Avatar
If you disconnect the DS at the Diff, how much will the Yoke slide into the Trans Tailhousing? Should be 3/4"-1" or 19mm-25.4mm
Old 09-27-2011, 06:29 AM
Hi SS 64. Thanks for your reply. I measured how far the DS moved into the gearbox and it came out at 26mm so that being the case it looks okay from the dimension you have posted. I bought a new seal and bush to put in to see if that is the problem.I tried taking the wheels off the axles and putting the car in gear and spinning them up but it made very little difference. I have been reading up on how to check the pinion angle relative to the gearbox angle which is supuposed to be about 2 to 3 degrees. So thats the next thing i will do. A guy in town at the Trans service shop suggested driving down the road , find the worst vibration speed and select neutral to see if the vibration is coming from outside the gearbox or try to eliminate driveshaft, driveshaft balance and wheel/tyre balance.
i guess its just a case of one thing at a time. Today i noticed a vibration coming from the 347 at 2000rpm while sitting up on the stands in neutral, but i am not sure thats enough to worry it. The torque converter was new and balanced so that "should" be fine.
Thanks
Al.
ID:	58609   Click image for larger version
Old 09-27-2011, 12:45 PM
I recently made a sheetmetal tailhousing for a Toploader 4spd. While designing the section to house the rear bushing and seal, i came across some dimensional info for the 28 spline slip yokes, and all were not the same with regards to the outer diameter. 1.500" is the most common, but there were smaller barrel diameters listed as well. I'd measure the OD of your yoke to make sure you have the right one.
I'd also measure the runout with the driveshaft installed. If the output shaft is bent or if you have a binding u-joint, that might be the easiest way to find it.
Pinion angle can also cause a vibration like that. I've got an Astrovan with composite leaf springs in the rear. Over time it developed a vibration in the rear that was very much like what you described. I jacked it up to check the u-joints, which appeared to be normal. I checked the slop of the transmission's output bushing, and it was very sloppy, but not leaking. But then I noticed that the pinion angle looked to be wrong, a bit nose-up. Turned out that the composite leaf spring on the pass side had de-laminated on the front half, allowing the nose of the diff to pitch up even more under load. I replaced the rear springs and the vibration was cured. Still has the sloppy output yoke fit, probably just normal wear for something with 320K.
Old 09-27-2011, 06:49 PM
Thanks for your reply aisr. I measured the slip yoke with a micrometer and it is a 1.498" shaft along its length. I bought a new bush and before its pressed in it has about .004" clearance instead of the .020 i measured with the yoke installed in place.
Its interesting your springs fixed your problem even if you have 320 k on that sloppy bush. It makes me think that putting this new bush in will not change much.When i took the shaft back to the place that fitted new joints and balanced it they suggested shimming the rear springs to change the pinion angle of the diff. Either up or down to prove it is the problem.
Just have to go one fix at a time and try it i guess. The tailshaft runs out .030 at the diff end so thats okay.
Thanks and cheers
Al.
Name:	Copy of Photo057.jpg
ID:	58620   Click image for larger version
connecting rod side clearance bill plise Engine 2 06-04-2011 08:20 AM
Engine - Rod side clearance 2old2fast Engine 11 11-07-2010 05:40 PM
Excessive Rod Side Clearance 68NovaSS Engine 5 11-30-2004 12:15 PM
sbc rod side clearance 85406 Engine 4 06-11-2004 01:32 PM
High side bearing clearance?? chevyelc81 Engine 1 05-04-2004 12:25 PM
