C4 A/T kickdown
Hello to every one I am new this board and need help. I recently bought a 67 Mustang with a 71 302 motor and c4 trans in it. This is the first ford I have ever owened. The owner had replaced the botor and trans but never finished it. I was under the car hooking up the trans linkage that looked like it was backwards. After taking the nut off the shifter to flip it when I went to pull the kickdown lever off the shaft came out alittle after looking at this the shaft would come completly out. I pulled the pan and found a lever that looks like it goes on the shaft but I can't tell how or where it goes. Can anyone help me on this? I have searched all over the net and can't find anything on the kickdown lever itself. I was told it would burn the trans up if not used is this true?
The kickdown lever is installed from the inside of the trans. If the lever (valve body side) is broken off, you will need to visit a trans shop for repairs. The kickdown lever is not able to be replaced with the valve body installed, but it can be replaced with the trans in the car. the kickdown lever provides passing gear and max throttle upshift timing, so it is important....
As far as the kickdown...all it is doing is shifting to second gear (people call it passing gear). We have been driving an 89 ranger with an 84 C5 in it for the last 5 years. No kickdown is hooked up. No matter what we tried the factory 89 linkage would not work on the 84 trans. We just downshift when passing. Then again...we built the trans and watch the tach when shifting. I agree though. Go ahead and get it repaired. It is not major in your case. It should not cost a lot. |
Thanks for the reply at least I have a better picture of the problem now.
| C4 kickdown | udu56 | Transmission - Rearend | 1 | 08-28-2007 09:11 AM |
| C4 A/T kickdown | NewMustangfan | Introduce Yourself | 2 | 08-24-2007 12:44 PM |
| Ford C-4 Kickdown Question | Z-Money Pit | Transmission - Rearend | 2 | 10-11-2005 02:34 PM |
| Replacing C4 with AOD | Mustang50Clay | Transmission - Rearend | 5 | 05-04-2004 05:24 PM |
| a/t kickdown cable adjustment | maddmaxx | Engine | 4 | 10-27-2003 08:04 AM |
