C4 trans in falcon - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2008, 06:04 PM
C4 trans in falcon
Ok I just put in a C4 in my 62 falcon wagon and I am wondering if I can use the column shifter instead addin floor? Is there any after market items out there that fixes this problem?
Thank you
Old 02-12-2008, 06:20 AM
pmeisel's Avatar
Glad the Jeep is on the road
Last wiki edit: How to identify a Ford V8
IIRC the column shift linkage should have been carryover, mostly, from 62 into the C4 era, so it should be doable.
4x4 1994 Trans problems ???? sinlow1980 Transmission - Rearend 2 07-16-2007 07:37 PM
Ford 8.8 rear and C4 or C6 trans in 46 Ford... 46FordSuperDeluxe Transmission - Rearend 9 04-27-2007 06:59 AM
Engine Locked after installing C4 Trans mustangcobra351w Transmission - Rearend 6 08-05-2004 12:49 PM
First time trans rebuilder...need tips! 4 Jaw Chuck Transmission - Rearend 14 06-23-2004 03:29 PM
c4 trans swap FASTFORD Transmission - Rearend 3 05-07-2002 12:11 PM
