Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - C4 trans ident?
Thread: C4 trans ident?
Old 12-28-2004, 03:36 PM
ptsherman ptsherman is offline
C4 trans ident?
I was given a C4 trans a while ago that I plan on using for a Pinto/351W swap. The bellhousing fits the block no problem.
I am missing the flexplate, though I do have the trans and torque converter.
Here's my can I *positively* identify what I have for a C4? Apparently there were several, and I need to figure out what I need for a flexplate in terms of how many teeth. It *may* even be out fo a Mustang II, which would be great for my application. There are numbers all over the trans, but I don't know which ones identify what the trans actually IS.
The shaft has 26 splines, and there are 7 bolts holding the bell onto the trans. The filler is on the bottom, where the pan bolts on.
Any idea how I can definitively tell what I've got here?
