the fluids mix fine with no adverse effects
At the Bonneville Salt Flats, first gear is known as 130 mph. |
1977 was when Ford started switching from Type F to Mercon ATF. In any event I would't worry about what is left in the TC. Refill w/the correct fluid- Type F will work in your case, and don't worry.
F or FA is what is supposed to be in a C4 - and those two do mix. Yep, there are those that say Mercon or other "wonder" ATF will work, but not in my C4 transmissions. Drain the torque converter, add 4 quarts, start and warm the engine/transmission and then slowly add the rest - and that final total number of quarts is somewhere in the range of 8-10 - until the level is at or near the top of the full line of the dipstick. Oh yeah, purge the cooler as well and at least pull the pan and clean the filter.
NAPA usually has F and always has FA, and it's a repackaged Valvoline product locally. (Dam' I really dislike auto parts counter jocks that don't have a clue.) Dave W |
there is no drain plug on the tc that i have seen so far and i figure there is about 3 qts or so in it ...only way to drain the converter is to unbolt tranny from engine and i dont want to do that ..lol...
![]() Dave W |
| Transmission fluid hot | jjrkjnoslen | Transmission - Rearend | 25 | 11-05-2009 03:20 PM |
| Transmission fluid for T-350? | bentwings | Transmission - Rearend | 3 | 09-10-2007 02:56 PM |
| Does transmission fluid ever go bad?? | schnitz | Transmission - Rearend | 3 | 09-15-2005 06:46 PM |
| Transmission Fluid c-4 | 85stangboy | Transmission - Rearend | 9 | 12-21-2004 07:15 PM |
| How Much Transmission Fluid? | EazyDuzIt102 | Transmission - Rearend | 8 | 01-12-2004 03:28 AM |
