C4 transmission help
Hey guys, this is my first post. I need major help. I bought a rebuilt C4, it set about a year before I used it. It will not shift on its own, when I shift it manually, it shifts first to second then when I go in drive it goes back to low. The valve body had stuck valves, fixed them still same thing. I checked modulator valve for the pin, it's in. Checked governor, it's not stuck. It has a good vacuum on modulator. I checked shift pattern on shifter and transmission. Revers works fine, low and second is fine. It has a shift kit installed, I don't know what kind. Any help is greatly appreciated.
First post - welcome aboard!!
If someone screwed up with drilling the two holes in the valve plate, forgot a ball or installed a spring in the wrong place when they did the shift kit, your shifts will be incorrect. Find out what kit was used, pull that valve out and try to find the instruction sheet. If that's correct, we can go from there. Also - is the servo, right hand side assembled correctly? Then under the filter there is a spring and pin under a tab that needs to be there for correct oil flow. I always suspect something is wrong with a rebuilt so I usually at least partially disassemble if for no other reason but to make sure all of the parts are there. Sticky spool valves on only a 1 year old rebuild would be cause for me to worry even more as these should have had enough ATF or at least some assembly Vaseline to keep them free. The one I currently have in my '31 sat virtually empty for 4 years and works just fine (except for a @#$% drip I cannot find) Dave W |
I don't remember seeing anything under the filter. As for what kit, I will have to try to find out. I bought it from someone who had it built for a drag car. Also the screw in the modulator is all the way out, Would that affect it? Thanks for the help.
Here's a real nicely done article about C4's:http://www.mustangandfords.com/techa...ion/index.html The modulator - might be junk. You only want to go 2-3 turns from factory setting. Also, take a look at the photo of the servo valve and how it controls the the band applications through intermediate gear. Clutches - high - all controlled by the valve body and how someone assembled it after "mods" That pin - see photo 32, between the guys two fingers there is a tab - and under it is a pin and spring. Double click on any of the photos to see a list. Dave W |
According to "PaulS" on another board, your problem may be: Quote:
I don't have kick down hooked up, but it is moving free. I'm not sure what year it is. I have it on a rack and run it up about 60mph, still no shift. It will not shift at all if I leave it in drive.
It shifts back to low gear.
Vintage is important. If this is a trans that was produced prior to 1969, the normal D position is actually 2. The "2" position is D on this type trans. These are called "green dot" transmissions and the valvebody is different. If the trans upshifts in the more normal "2" position, it is a green dot valvebody. Start with the shifter in 2 and see if it shifts.
Still no shift.
Time for a trans shop with early transmission experience. You are missing something.....
OK guys, I had time to check it today. I do have a green dot valve body. Should I try to fix this transmission, or buy another one?
Is your intent to have this trans work as a stock type unit or street/strip unit?
I intend to put it in gear and drive. lol
the green dot valve body can be replaced with a 1967 , 68 or 69 valve body for regular shift pattern PRNDSL ... place shifter in "D" and trans upshifts and downshifts in all 3 gears.
this valve has the shifter linkage detents in the valve body as needed
At the Bonneville Salt Flats, first gear is known as 130 mph. |
| what transmission to use??? | ericehsbrown | Transmission - Rearend | 2 | 12-13-2007 12:47 AM |
| CV Transmission | EastCoastSBC | Transmission - Rearend | 1 | 03-14-2006 07:27 PM |
| Transmission ID | sabino56 | Transmission - Rearend | 3 | 10-31-2005 08:30 PM |
| transmission | erythnul | Transmission - Rearend | 2 | 03-31-2005 06:19 AM |
| 700-r4 transmission | riverrat | Transmission - Rearend | 2 | 01-21-2003 09:45 PM |
