C4 Transmission Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2002, 10:15 PM
Post C4 Transmission Help
Hey this is my first post and I was wondering if anybody knows anything about shifting with a c4 tranny. I have a 65 Mustang with a K code 289 and a c4 transmission. I was wondering if it is possible to manually shift and downshift with this stock but recently rebuilt transmission. Somewhere a long time ago I read something about with an old ford transmission (can't remember which one) that if you start in low and drive low as high as you want then shift to drive and back to low, it shifts into second, and then shift to drive for third. Would that work with my transmission. Any help would be greatly appreciated. I would really like the control of a manual but can't afford the swap right now.
Old 08-12-2002, 05:52 AM
dmorris1200's Avatar
doesn't play well with others
Post
Well I've manually shifted every C4 trans I ever had. The oldest one I've ever had was a '68. The ones I've had all had P,R,N,D,2,1 on the gear selector. If you start out in '1' then shift to '2' when you're ready for second gear. Then put her in 'D' when you're ready for third. Is this how your gear selector is set up? Whats it say on the shifter? Never owned a '65.
BUILT FORD TOUGH
Old 08-12-2002, 07:56 AM
Post
It has a low. Then it has a dot which is drive because it starts in first, then goest to second, and then to theird. Then it has a dot with a circle around it in which the transmission starts in second and shifts to third.
Old 08-12-2002, 09:32 AM
Post
Well that sounds exactly like a C4 shift pattern except wrong order. With the selector in second gear a C4 will start off in second then go to third. It doesn't make sense that she would go from neutral, to second, to drive, then to first on the gear selector. The order should be neutral, drive, second, then first. That way you pull the selector all the way down to first (low 1) then just click it once to second and then one more click to drive (third). From the way you describe it she goes neutral-second-drive-first, which doesn't make sense. Unlees there's been valve body modifications or something else. I'm not a trans expert, I'm just going off experience of all the C4's I've owned. But they've all been stock and '68 or newer. I know we've got a few trans guys here, they may not have seen the post yet though.
BUILT FORD TOUGH
Old 08-12-2002, 08:01 PM
The Vandal's Avatar
Engine Tech Addict
Post
I had a 66 coupe with a 289/C-4 and if you put it in drive it would shift from 1st to 3rd which was fine most of the time. When I'd race I had to start out in 1st (shifter all the way down), then click up one notch (2nd) and back to 1st to get it into 2nd, then up into drive to get into 3rd. I never knew why but once I knew how to do it I didn't really care. Besides, I was seventeen........lol.
The Vandal
Old 08-13-2002, 08:03 PM
Post
I've tried that but when I shift back down into first from second, it downshifts back to first.
Old 10-31-2003, 08:11 PM
tim1965stang's Avatar
C4 Red Dot
This is normal for the Trans to shift from 2nd to third in this position it was designed for the more torqed motors.
the car only wieghts 2800 lbs and will move just fine from 2 to third
if you want to leave the line yesterday then then pick the one that starts in first and smoke there ***
tim
Old 10-31-2003, 09:15 PM
airworld2's Avatar
c4
OKs Mr d morris your the ford guy right( just messing with you)
the old c4 tranny 64 1/2 to 66 was semi auto c4 as they where called
drive 3 tranny started in 2nd then shifted to 3rd
drive 2 position started in first shifted to second and then shifted to third gear
drive 1 or low on the shifter was first only
I don't know how many first time mustang owners have come to my shop thinking they car was not working correctly, I have to explain the working of the old tranny's
some shop's have change the valve bodies to correct this so called trouble to make the customer's happy
airworld2
Old 10-31-2003, 11:03 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
interesting how a post that is 14 months old is brought back to life.
good info
Old 11-01-2003, 11:07 AM
I think I know what you heard and why.
The AOD (automatic overdrive Trans) has 3 + OD but only 3 selector positions.
Start in 1 and shift to 2 as soon as the shift engages you have to pull the shifter back to the 1 hole to hold second gear or it will immediately go to 3rd.
When you run up to the desired rpm range go back to the 2 hole to take 3rd and then to the 3 hole to get 4th/od if you need it but your probebly through the 1/4 by now and wont need it.
Of course this wont apply to your c4.
Doc
Wow yeah just noticed that this post is that old, Bet he's got it figured out by now, lol
Old 11-01-2003, 06:43 PM
adtkart@aol.com
I remember having a customer, years ago, that came in cause he had a problem with his 67 Mustang. The thing was shifting 2 times when it was in drive. He had always had the earlier Mustangs and never had one shift like that. He thought someone had "hot rodded" it, and wanted it back the way it was supposed to be.
