c4 transmission masive pump seal leak
I was driving [77 bronco c4 auto]with no problems then most of the fluid puked out the pump seal, i replaced the seal with no problem filled it and started it up and it puked up most of the fluid again.The old seal looked fine and there was no groove on the torque converter. it would be a great help if some one had a answer as this is my daily driver and im finding it hard to carry heavy loads on my back.
Moving to Transmission forum.
Dan
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
Two things come to mind.
1.) Did you lube the new seal when you installed it? (Been there, done that) 2.) Have a look at the dowel holes on the bellhousing to make sure they haven't oblonged. (Again ... been there ) Oblonged dowel holes will allow the trans to shift with engine torque ... causing the TC to run off-center to the pump. This results in rapid wear of both the front pump bushing and the seal. |
A plugged transmission vent will cause oil to puke out the front and/or rear seals. Vent is located on the top front of the tail housing from 1970 and up.
I lubed the seal ,in fact the old seal looked fine, there was some polishing on the converter from the seal but no wear. the dowels are tight. the vent tube could be pluged i just rebuilt the transfer case a month prior to this and something could have happend . The pump bushing could be it to I will check the vent and if thats good i will drop it and check the bushing ,and flush out the lines.I hope one of these works I dont want it to be something internal,thanks your advice is much appreciated.
The converter hub or the weld on the hub may be cracked too.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
i looked for obvious cracks, found none, but someone suggested the governor.
With out a proper bench pressure check on the converter for leaks, I would not rule it out. You need have the pump bushing and related area verified to be in good condition. Good luck
| Transmission front pump leak | Chevy350Sb | Transmission - Rearend | 2 | 10-15-2009 05:57 PM |
| 1991 Chevy Truck transmission seal leak | D0UG | Transmission - Rearend | 5 | 08-01-2008 07:59 PM |
| SBC Front pan seal leak | Richard H. | Engine | 10 | 03-16-2007 12:44 AM |
| HV oil pump makes oil filter seal leak | WBrianS | Engine | 13 | 11-20-2003 01:56 AM |
