c4 transmission question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2002, 10:29 PM
Post c4 transmission question
I put a rebuilt '73 ford c4 transmission in my truck which originally had a '71 3 speed maunual. The c4 shifts REALLY hard, especially when I shift from "Park" to "Reverse" or from "Park" to "Drive." It SLAMS into gear. Is this adjustable??? If someone can help, I would really appreciate it.
Thanks.
Old 10-24-2002, 03:10 AM
roys63's Avatar
Post
What is the idle speed? need to have it down about 600 800 RPM stock motor, is this all new or rebuilt? It may loosen up after driving some?
Old 10-24-2002, 03:14 AM
woodz428's Avatar
Troll Hunter
Post
The vacuum modulator might need adjusted or it could be bad. Pull the hose off the end and if there is trans fluid in the hose replace it, if it's clean you can stick a small screw driver into the nipple and adjust the shift harshness, clockwise to soften it. I'd start with the idle speed first though.
Old 12-18-2006, 07:07 PM
c4 shift
I also have a c4 and i like that firm shift. I do notice that reverse is harder than drive though. If i lower my idle that will take care of that.
Old 12-18-2006, 07:59 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Please read the dates on threads you are looking at.
You have brought up a 4 year old thread..
No harm , just a heads up type FYI
