C4 Vette Rack With Ford Pump? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2010, 12:20 PM
Greetings!
Doing a 56 F100 with the Corvette Flatout kit, while the engine is on the stand it would be an ideal time to address this potential problem with someone that has "been there, done that".
The steering is a rebuilt F51 C4 Corvette rack, the pump (and engine) is from a 88 LTD.
My question, will the Ford pump produce enough (or too much) pressure/volume for the Vette rack?
Should I adapt a GM style pump or install a bypass flow control valve or will it be OK the way it is?
Thanks!
Old 12-26-2010, 02:40 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Ford PS pumps put out less pressure then a Saginaw power steering pump, if I were doing this, I'd use a Sag pump w/remote reservoir.
Rich
Old 12-26-2010, 03:25 PM
Originally Posted by richard stewart 3rd
Hi,
Rich
Thanks Rich, what would I find one of these pumps on?
Would they have a 7 groove flat belt pulley?
Old 12-26-2010, 09:07 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
Since you got it, hook it up and try it!
Andy
Old 12-27-2010, 03:13 PM
Ford vans through the 80s used a GM Saginaw pump with a serpentine belt on both 302s and 351s.
Old 12-29-2010, 07:32 AM
AGR makes a pump for that application
Old 12-30-2010, 01:45 PM
Hi,
68 - 72 Factory BB trucks.
Newer GM Vehicles like full size vans, the Astro & Safari use a small remote reservoir mounted on the firewall. Check the yards.
Rich
Mustang II power rack/GM pump 57halfton Suspension - Brakes - Steering 11 05-24-2017 11:09 AM
Fluid for Ford rack to GM pump ? jcarter Suspension - Brakes - Steering 5 12-11-2006 11:03 PM
Setting up a GM pump for a M11 rack and pinion? jcarter Suspension - Brakes - Steering 3 11-23-2006 06:32 PM
MII Power Rack w/Chevy PS Pump ttrovato Suspension - Brakes - Steering 2 07-02-2003 04:12 PM
92 Buick power rack pinion using 68 Ford pump? JAY221 Suspension - Brakes - Steering 2 09-14-2002 11:21 AM
